Introduction: How to Make Crystal Glass Bead Necklaces With White Pearl Beads
Looking for bead necklace designs? What about this crystal glass bead necklace? Just check the detailed tutorial below to see how to make this crystal glass bead necklace.
Step 1: Materials and Tools Needed in DIY the Crystal Glass Bead Necklace:
8mm White Round Pearl Beads
6x4mm Crystal Suncatcher Abacus Glass Beads
Golden Spring Clasps
Golden Jump Rings
0.2mm White Fishing Wire
Stainless-Steel Scissor
Step 2: Make the First Part of the Crystal Glass Bead Necklace
1st, cut about 300cm 0.2mm white fishing wire. Then, thread a golden spring clasp to it and make some knots with the wires (as shown in the picture);
2nd, cut off one wire. Then, add 6 6x4mm crystal suncatcher abacus glass beads and 5 8mm white round pearl beads (as shown in the picture);
3rd, add 3 6x4mm crystal suncatcher abacus glass beads (as shown in the picture);
4th, cross the wire through the crystal suncatcher abacus glass beads (as shown in the picture);
5th, add 5 6x4mm crystal suncatcher abacus glass beads (as shown in the picture);
6th, cross the wire through the crystal suncatcher abacus glass bead (as shown in the picture).
Step 3: Make the Second Part of the Crystal Glass Bead Necklace
1st, add 2 crystal suncatcher abacus glass beads, an 8mm white round pearl bead and 2 crystal suncatcher abacus glass beads (as shown in the picture);
2nd, cross the wire through the crystal suncatcher abacus glass bead (as shown in the picture);
3rd, cross the wire through the two adjacent crystal suncatcher abacus glass beads. Then, add 5 crystal suncatcher abacus glass beads (as shown in the picture);
4th, cross the wire through the crystal suncatcher abacus glass bead (as shown in the picture);
5th, cross the wire through the crystal suncatcher abacus glass beads. Then, add 2 crystal suncatcher abacus glass beads, an 8mm white round pearl bead and 2 crystal suncatcher abacus glass beads (as shown in the picture);
6th, cross the wire through the crystal suncatcher abacus glass beads (as shown in the picture);
Step 4:
7th, refer to the above steps to make four more such glass beads and pearl beads patterns. Then, add 5 crystal suncatcher abacus glass beads and cross the wire through the crystal glass beads (as shown in the picture).
Step 5: Make the Third Part of the Crystal Glass Bead Necklace
1st, add 2 crystal abacus glass beads, an 8mm white round pearl bead and 2 crystal abacus glass beads (as shown in the picture);
2nd, cross the wire through the crystal abacus glass bead (as shown in the picture);
3rd, cross the wire through the crystal abacus glass beads. Then, add an 8mm white round pearl bead and 4 crystal abacus glass beads. Cross the wire through the crystal abacus glass beads (as shown in the picture);
4th, add 5 crystal abacus glass beads and cross he wire through the crystal abacus glass beads (as shown in the picture).
Step 6: Make the Rest Part of the Crystal Glass Bead Necklace
1st, refer to the above steps to make five more such bead patterns (as shown in the picture);
2nd, add 7 crystal abacus glass beads and 5 8mm white round pearl beads. Then, add a golden jump ring. Fix it and cut off the excess wire (as shown in the picture).
Step 7: Here Is the Final Look of the Crystal Glass Bead Necklace.
The crystal suncatcher abacus glass beads make this crystal glass bead necklace stunning. In fact, once you grasp the basic bead pattern, you can find it's a piece of cake to make the whole necklace. Have a try if you like this crystal glass bead necklace.
