Introduction: How to Make Flowers in a Vase
i made this for a school project and i just love how it came out this is a 12 step process it takes a very long time to make it took me about a week and a half to make
paper
paper cutter
glue
Step 1: Step 1: Vase
cut multiple strips of paper about 1cm (note: you can buy paper that is already cut if you don't want to cut it)
Step 2: Step 2: Vase
glue two strips that you cut together this will make your circle bigger and it will be easer for you to make the vase (note the more strips you add the bigger your circle will be)
Step 3: Step 3: Vase
roll the strip of paper using this quilling tool (note: you will have to do this multiple times)
Step 4: Step 4: Vase
glue the edge and then your left with this.
Step 5: Step 5: Vase
you are going to stack the little circles you made until it looks like a vase (note: i would use something that is circle for reference to help you make the vase) it should look like the picture above
Step 6: Step 6: Flower (middle Part)
so your going to de the exact same thing for what you did to make the vase but instead of gluing it right away you're going to let it go then your going to glue it (look at pictures for reference)
Step 7: Step 7: Flowers Petals
you're going to do the same thing you ditto make the middle part of the flower the your going to make a crease so it looks like a tear drop (should look like above picture)
Step 8: Step 8: Flower
then your going to glue the petals to the middle of the flower and then you can take a pice of whiter os something to make a stem (note: you will need 18 petals)
Step 9: Step 9: All Done
the you put your flowers in your vase and you are done
