How to Make Hand Candles
Intro: How to Make Hand Candles
I ran across a tutorial on how to make a candle by dipping an inflated balloon into wax. It got me wondering if I could do the same with a latex glove. The thing about the balloon candle is that it doesn't have a wick, you just place a tealight inside of the wax shell. I didn't like that, I wanted my hand candle to have wicks on the fingers. So instead of dipping the glove in wax, I poured wax into the inside with wicks running through the fingers. To make my hand candle more ghoulish for Halloween I added some red wax to make it look like the fingers are bleeding.
In this instructable I will show you on how to make your own hand candle.
Warning the flames can burn very high, use caution, never leave candle unattended.
STEP 1: Materials and Tools
- Candle wax (I used white/off white and red for the blood)
- Powder free disposable gloves/exam gloves (ie latex)*
- Candle wicks
- Pot for melting wax
- 20 gauge wire
- Clamps
- Duct tape
While I was writing up this Instructable it occurred to me that dish-washing gloves may be used as well. They are much thicker and likely won't tear, although they often have a lining inside (you can probably just turn them inside out) .
STEP 2: Preparing Glove
- Poke a tiny hole in the tip of the each finger you want to have a candle wick.
- Tie knots in the wicks about 1 cm from the end.
- Poke the wick through the hole from the inside (the knot should be inside the glove right against the tip).
- Cover the finger tip with duct tape covering the wick and the hole to prevent the wax from seeping out.
STEP 3: Making a Holder
To make it easier and safer to hold the glove open while pouring hot wax into it I used some wire to fashion a loop. I slipped the loop around the opening and used some clamps to hold it on. To make sure that the wick(s) stay centred in the fingers I knotted them together and wrapped the loose end around a pencil to anchor them (see image below).
STEP 4: Wax
A word of caution, be careful when pouring the hot wax as the gloves may tear and spill the hot wax everywhere.So pour away from yourself fingers to prevent burns.
The amount of wax you will need depends on the size of glove that you are using, you can fill a glove with water and then pour it into a measuring cup to get the correct amount. It is a good idea to melt more than you need in case you spill. Place a plate or tray under your glove to catch any drips or leaks. Melt your wax in a pot on the stove then slowly pour it into the glove. Once filled hang it somewhere to allow it to set (I hung mine from a banana hanger). I placed a cork between the thumb and fingers since the thumb seemed to sag.
Hand Gestures
Before the wax sets you have an opportunity to bend the fingers (and tape them up) if you want to make hand gestures, such as a peace sign, Vulcan salute etc.
Hand Gestures
STEP 5: Admire Your Handy Work
Once the wax has fully hardened you can peel/cut off the glove. Trim the end of the wick from the bottom. If the bottom is uneven you can use a knife to carve it flat so that it can stand without tipping.
STEP 6: Adding Red
Simply melt a small amount of red wax. With a spoon scoop up some of the red wax and drizzle around the fingers, letting it drip down the hand.
44 Comments
Smoke_me_a_kipper 13 years ago
Several of these hand candles have been recalled due to fire hazard. When the fingers burn down they really burn due to all the paraffin melting. Take care.
http://www.consumersrevenge.com/reports/candle4.htm
aspendog14 10 years ago
adding steric acid reduces the melt rate in candles
ChrysN 10 years ago
Thanks, that is good to know.
hontz778968 3 years ago
strixowl 13 years ago
shunt 666 5 years ago
ChrysN 13 years ago
VividF 9 years ago
sdhardie 11 years ago
ChrysN 11 years ago
wocket 13 years ago
bde cock 13 years ago
kazmataz 13 years ago
ChrysN 13 years ago
sunshiine 13 years ago
aricooperdavis 13 years ago
^ like
Johan8335 13 years ago
lol
HAHAHAHAHAHAHAHA
