Introduction: How to Make Key Holder
About: Interested in doing different things in carpentry I'd love to share my knowledge and projects with everyone. It's been more than a year since I launched the YouTube channel
I made the Key Holder a few months ago .
I saw that it might be interesting to you too
At first glance, you may find it hard and need special equipment
But when you start seeing how you build, you realize how simple it is
The build video is completely at the door of the YouTube channel
1-A tool for cutting (manual or motorized)
2- sandpaper
3. Wood oil
4-driel
Woods used in this project
Maple
Ayous
Step 1:
I picked a piece of maple .I started cutting wood
To create such a design that you can see, I had to use a wood part that had the same texture
To better stick the two pieces of wood together, I cleaned the edges with sanding
I applied the wood glue to the required amount between the two cuts
I clamped him tight
Step 2:
I brought a second cut of wood, which I considered for the front of the key
I carefully measured the exact number that I needed
I JOGGED TO CUT THE HOOK WITH THE REQUIRED DRILL
I closed the hooks once to check the size
which was right for me
This hook model I had had easy installation
In this way, a drill is first struck in wood .Then we installed a hook that was bolted
Step 3:
When the sticks I glued together dried up
I found a required pattern to draw a circle on my stick
Then I cut and started sanding
The second cut off that I had hooked, I carefully walked my round wood center
and I glued together with glue
Step 4:
At the end of the sanding phase, I broke down and used wood oil
I think it was pretty .What do you think ؟؟
