Introduction: How to Make Laser Signs for Rubbish Bin
About: Laser professor
Laser signs for rubbish bin can guide people to good habits. It keeps our spaces clean by showing exactly where to throw waste.
Now is going to use a Thunder Laser system to make a Rubbish Bin Sign. Let’s start to explore fun with the laser!
Material: 1.3mm two-tone ABS sheet blue to white
Laser head: standard head
Laser engraving machine: Thunder Bolt Pro32 55watt
Step 1: Setting Parameters:
Processing Mode:
Layer Yellow Engraving speed: 1000mm/s
Layer Yellow Engraving power: 5%
Layer Red Engraving speed: 1000mm/s
Layer Red Engraving power: 30%
Cutting speed: 40mm/s
Cutting power: 80%
We set two engrave layers for a more varied layered look and the finished laser signs shows a light blue body with white trim on the sides.
You can also draw on CorelDraw and then click on the laser plug-in to switch to the laser software. Set the appropriate parameters on the laser software and click Download to transfer the design to your laser engraving machine.
Step 2: Assemble It:
Place the ABS on the work table of the laser engraving machine, move the laser head to the proper position, adjust the focal length, press the “Origin” on the LCD control panel to set the starting position, and then press the “Start” to start the work.
Get the laser signs cut out and scrub it with a brush and water to remove dust, Let’s do it by yourself.
#Laser Engraving #Laser Cutting #Free Laser Files #Laser Crafting #Rubbish Bin Signs #ABS Sheet Craft #Custom Laser Signs #DIY Projects #Craft Tips #Useful Signs #Smart Workshop Hacks #Public Space Cleaning Solutions
