Introduction: How to Make Simple Electric Elevator Model From Cardboard. Model for Science Project
In this project, I wanted to make an electric elevator model for your science projects using simple recycled materials and cardboard.
• 5mm foamcore or Cardboard
• 250RPM DC 6V Motor
• 2mm Galvanized Steel Wire
• 3mm Ferrule Terminal
• Plastic Pulley harvested from Old DVD burner
• AAA Battery & Battery Holder
• AWG24 Wire harvested from old electronics
• ON/OFF/ON Slide Switch harvested from old electronics
• Optional for Cabin Light
- 5mm LED
- CR2032 Battery
- On/Off Slide Switch harvested from old electronics
• Nylon thread
Print below PDF file on A4 Paper (or Sticker) for proper cut.
Step 1: Apply Plans to Cardboard
Stick plans onto 5mm thick foam core or Cardboard.
Step 2: Cut All Pieces
Cut all the pieces from the marked lines with a utility knife.
Step 3: Glue Facade Support
Glue the support pieces to the facade.
Step 4: Cut Guide Wire
Cut 2mm Galvanized Steel Wire, streighten with electric screwdriver.
Cut 26cm 2pcs straight wire for cabin travel guide.
Step 5: Facade Piece Assembly
Glue Facade Piece onto Base.
Step 6: Drill Holes
Drill holes for wire guide
Step 7: Stick Top Plate
Stick top piece onto facade piece
Step 8: Cabin Assembly
Step 9: Bushing From Ferrule
Heat up cable ferrule with lighter and remove the plastic part.
Step 10: Mounting Guides
Glue the 26cm long straight wires by attaching the bushing pieces between the upper and lower parts.
Step 11: Cabinet Mount
Glue the cabinet between the Bushing pieces.
Step 12: Cabinet Movement Test
Test that the cabinet moves freely on the rod guide with bushing parts.
Step 13: Mount Pulley
Mount pulley on 250rpm motor shaft.
Step 14: Cabin Rope Connector
Cut off the bottom of the syringe plunger and make a hole in it. Stick it on the cabin for cabin engine connection.
Step 15:
Tie a rope to the Cabin Rope Bracket.
Mount the DC motor at the top of the structure and glue the cabin rope to the plastic pulley attached to the motor shaft.
Step 16: Wiring Up Electronics
Solder the cables to the slide switch in accordance with the schematic diagram.
Step 17: Electronic Assembly
Step 18: Passengers
Don't forget the passenger
Step 19: Have Fun!
Enjoy!
