Introduction: How to Make a Bath Bomb Without Citric Acid
Ingredients-
Large glass or metal bowl
Smaller glass/metal bowl/cup
- Whisk or metal fork
- Spray bottle with tap water inside (optional)
- Mold (I use a star mold, but an ice tray will work well)
- Measuring cup
- 1/2 cup baking soda
- 1/8 cup cream of tartar
- 1/4 cup cornstarch
- 1/4 cup salt (Epsom salts)
- 1 teaspoon essential oil (I use lavender and peppermint) (even perfume would work)
- 1/2 tablespoon oil (any type of skin care oil) (I used Olive Oil) (optional)
- 1 or 2 drops of food coloring (Add as necessary)
- Lavender flower buds (entirely optional)
Additional notes- If you want multi coloured bath bombs (blue and purple, black and red, ect) then follow step 1 and the split the contents into two separate bowls. Follow step 2, but create two colors in two separate containers. Mix the two wet bowls to the two separate dry bowls (color A with A bowl A, ect). Follow step 5, but layer the colors. Follow the rest of the instructions the same.
Step 1: Combine the Dry Ingredients Into Large Bowl
This will be the dry bowl. Mix the baking soda, cream of tartar, cornstarch, and salt (Epsom salts) into the larger bowl and mix thoroughly with whisk or fork. Add the lavender buds if you want.
- Large glass or metal bowl
- Whisk/fork
- Lavender buds (entirely optional)
Step 2: Combine the Wet Ingredients Into Smaller Bowl.
This will be the wet bowl. (see additional note after ingredients if you want multi colored bath bombs) This step can be altered, and you could easily add more or less depending on what you want. The color will become more white when added to dry bowl. Mix the essential oil, skin care oil , and 1 or 2 drops of food coloring (Add as necessary). Add less essential oils if you don't want the smell to be as strong. Be careful when adding the oils, as a little goes a long way.
- 1 teaspoons essential oil (I use lavender and peppermint)
- Smaller metal bowl or cup
- Whisk/fork
Step 3: Mix the Contents of the Small Bow (wet) With the Contest of the Big Bowl (dry).
Combine the two mixtures and stir in gradually. If you dump the wet in all at once, then the bath bomb won’t fizz in the bathtub.
- Contents of the wet bowl
- Contents of the dry bowl
- Whisk/fork
Step 4: If Its Too Dry
If the mixture of the two is dry (if you can't squeeze it into a shape and it won't hold), then spray with water or add by the drop. Mix with fork.
- Spray bottle with water
- Fork
Step 5: Put the Mixture Into the Mold You Chose
Be sure to pack it down very tightly.
