Introduction: How to Make a Bracelet
by: Anna A.
Step 1:
Decide how many colors you want and then cut the colors into long pieces of string that are the same length
Step 2:
Fold the strings so that they are the same length on the both sides
Step 3:
Tie a knot at the top
Step 4:
Pull one color all the way over to the right
Step 5:
Put into a 4 shape
Step 6:
Lift the other strings up and put your fingers inside the four grabbing on to the string
Step 7:
Pull the string through
Step 8:
Pull the string all the way to the top
Step 9:
Make sure it is tight
Step 10:
It should look like this
Step 11:
Once you get to about this point you switch colors making the next color go all the way to the right
Step 12:
When you get to the point you want put the charm on one string
Step 13:
Pull the charm all the way up
Step 14:
Keep going normally
Step 15:
Measure it to make sure that it is as long as you want it
Step 16:
Pull the rest of the string through the loop
Step 17:
Tie it in a knot
Step 18:
Make many knots till it is about this thick
Step 19:
Cut the extra string off
