Introduction: How to Make a Card Bridge in Minutes!
This is how you can make your very own card bridge. There is really no purpose to this other than that it looks AWESOME!
You need a deck of cards. I used a set of Uno cards, These are good because they are not to big or small. The cards also can not be new. (New card slip around to much)
Step 1: Build Support
You have to lay the cards down in a way that the front card always has a card on top and below it. This will hold it in place.
Step 2: Add More
If you see this happening you need to put a card right in the valley of the two cards that are sliding. The new card will hold both of them in place.
Step 3: Just Keep Adding More!
There is no specific way to lay the cards. Just make it so they don't slip and they support each other.
Step 4: Other Side
Start doing steps 1-3 again on the other side of the gap. You don't want the gap to be really far because the cards won't hold.
Step 5: Connect in the Middle
Once the card piles reach the middle carefully lay one card in the very middle. After that you can either stop or make it stronger! Have fun building!
