Introduction: How to Make a Circuit Board at Home
First print your plan on a paper by laser jet type of printers
Step 1: Print Your Plan on the Paper by Laser Printer in the Mirror Plan
Step 2: PCB Board
Cut the fiber to the required size of the map
Step 3: Washing Grease and Waste From PCB Board
Befor anything wash surface of the board after cutting
Step 4: Paste the Paper Map on the Copper Fiber Section
Step 5: Heating by an Hot Iron
Press hot iron onto paper with out fog !
Step 6: Cleaning the Board After Ironing
After making sure the map is pasted on the pcb, gently peel off the paper and gently peel off the sticky paper with water.
Step 7: Repair Incomplete Parts of the Map
Step 8: Working With Acid
Use of perchlorophoric acid to eliminate unnecessary parts
Shake the bowl slowly while working with the acid
Wear eye protection and gloves when working with acid
Step 9: Final Time
After finishing the acid work, wash the piece with water and remove the varnish and colored materials with a wire scotch.
Step 10: Drilling Time
Drilling the base holes of the circuit parts
Step 11: Finish Time
board is reedy to assemble the circuits parts
