Introduction: How to Make a Glowforge Windmill
This Is a homemade Windmill that will charge a light, a fan, or any other electricity using device.
Step 1: Matierals
You will need a Cardstock, Draftborad, and a motor.
Step 2: Making Your Materials Work
You will cut the Blades from Cardstock. The Base and Stand will be cut out of Draftboard.
Step 3: Assembleing the Windmill
Stick the Stands(the things with long poles and a circle in the middle) In the base(draftboard square). Then attach the blades to the Motor. Stick your motor into the stands.
Step 4: More Stability
You can hot Glue the stand to the motor if you want more stability. You also can use a Solder Iron to connect a light bulb, fan, or other electricity things. NOTE: it will not charge Tablets, Phones, Watches, or any other electricity using devices.
