Introduction: How to Make a PVC Laptop Stand
This is laptop stand made from the pvc pipes it is height adjustable can be place in higher and lower according to your need ,making this laptop is simple and easy.
If you like this instructable please vote for it and if you don't understand something please watch the video.
4 inches pvc pipes x 4
7 inches pvc pipes x 4
11 inches pvc pipes x 2
t joint x 2
T and U joint x 4
U joints x 4
1.5 inches of pvc pipe
Nut and bolts
8.5 inches pvc pipe x 1
Step 1: Making Bottom Part
making a bottom part of laptop stand ,Need to connect all the pvc pipe and connectors according to the pictures pattern,
Connect the 4 inches pvc pipes to a t joint then start connecting the 7 inches and 11 inches pvc pipes to the TandU joints forming a rectangle.
Step 2: Making Top Part
Place the 4 inches pvc pipe to t joint and then to u joint following by the 7 inches to u joint to 11 inches pvc pipes forming a top part.
Step 3:
Place the 1.5 inches pvc pipe in to the both parts of t joint,Drilling a hole on the u joint and placing nut and bolt for laptop support
Step 4:
Drill the hole on the bottom part side way from 1 inches apart and drill one hole on the side way of upper part
Step 5:
Take a 8.5 inches pvc pipe and drill hole on the both ends 1 inches gap,place the nut and bolt and warm that area with a lighter then tighten the bolts.place that stand support on the holes of upper and bottom part.
Step 6:
We can adjust it is height by the support placing the other holes ,it can carry and hole the laptop to adjusted height.
If you like this instructable please vote for it.
