Introduction: How to Make a Secret Commiunicator Using Micro Bit
I was inspirated in 'othermachines' you tube chanal.
here what i got from it -https://youtu.be/mqlMo4LbfKQ
Here what i added on my self -
- lcd displays
- key pad for other micro bit
- power banks
- Extra code for it
2 - micro bits
2 - lcd displays with i2c modules
2 - 4×4 matrix keypad
2 - mini breakout boards for microbit
2 - power banks
Step 1: Suplying Items
Fitstly supply these all items
Step 2: Plug in Micro Bits to Mini Breakout Boards
It's very easy to plug in.
You want to do is just push inside micro bit to break out board
Step 3: Connect 4×4 Matrix Keypad to Micro Bit
Step 4: Connect 16×2 Lcd Display to Micro Bit
Connect lcd display using jumper wiers
Step 5: Get Power to Lcd Display From Power Bank
Micro bit's output voltage is 3V but lcd display needs minimum 5V. There for i used two female jumper wiers
and connected to usb cable
Step 6: Lettering Key Pads
Write letters on paper and stick it to keypad using double tape.
pressing 'shift' will call the shift function.
Shift function sets A to O , B to O , C to Q etc...
(It is showed in a picture)
Step 7: Assembling All Items Together
Assembling all items will make it portable.
Step 8: Coding
Get source code here-
https://makecode.microbit.org/_A6wE8CD4fhA1
Step 9: How to Use
Type words and press 'B' button in micro bit
Words can be see in other micro bits lcd display.
