Introduction: How to Make a Storage Pool
Hello guys! Today I'll teach you how to add a permanent drive to windows 10.
Step 1: Create a VHD.
If you've created a virtual disk, you should probably us it. Your VHD will permanently stay in-put. If lost, you should click all the VHD that makes it up.
Create a VHD
Steps to add a hard drive to This PC in Windows 10:
Step 1: Open Disk Management.
Step 2: Right-click Unallocated (or Free space) and choose New Simple Volume in the context menu to continue.
Step 3: Choose Next in the New Simple Volume Wizard window.
Step 4: Specify a volume size that is between the offered maximum and minimum sizes, and then click Next.
Step 5: Assign a drive letter to the new hard drive and tap Next. Tip: The default drive letter assigned to the new partition is E.
Step 6: Tap Next to choose formatting this hard drive.
Step 7: Hit Finish to complete hard drive addition and exit the wizard.
Tip: In the pop-up Microsoft Windows dialog, choose Format disk to go to format the new hard drive so that you can use it, such as storing data in it.
Step 2: Making It Stay In-put.(Last-Step)
To make it to stay in-put is an easy thing. Follow the steps below:
1.Connect the storage drives to your Windows 10 PC.
2.Go to the taskbar, type Storage Spaces in the search box.
3.Select “Create a new pool and storage space.”
4.Select the drives you want to add, and then select “Create pool.”
5.Give the drive(s) a name and letter.Choose “Create storage space.”
You can add 5 drives to it. You'll use 11.9GB of 319TB
Hint: You should probably make the VHD 64TB
Thanks.
