Introduction: How to Make a Toothpaste Squeezer MacGyver Style!!
Is it that you have toothpaste in the tube but cannot get it out?Well this is the problem most of us (including me encounter).
Now you need not buy those squeezer.
Can you imagine how this problem can be solved with things that are used everyday???You can now solve the problem with the unexpected thing like cotton swab that are available at your home.Untill you proceed to the next step keep thinking for the solution.
This is the time you become creative and solve the problem.
NOTE-THE INSTRUCTABLE IS ENTERED IN THE MACGYVER CONTEST.PLEASE VOTE FOR ME IF YOU LIKE IT.
Step 1: Gathering the Things
The things required are very simple and you would get them at your home itself (thats why it is free).
All you need is-
1. 2X Rubber bands
2. 2X Cotton Swabs(or two small sticks/nails)
3. And of course the Toothpaste( with which you are going to experiment)
After you collect the materials proceed to the next step.(which you cancollect while reading the i'ble!!)
All you need is-
1. 2X Rubber bands
Step 2: Putting It Together
There is one thing I want to make clear before we proceed and it is you can use nails instead of cotton swabsthe only issue being you can get a cut from it.
As I have a younger sister I used cotton swabs.Even cotton swabs work just fine.If you use nails be sure to hammer their pointed ends before using them.
I used the KISS method Keep It Simple Stupid so it was easy to make it.
Now proceed as follows-
1.Take two cotton swabs and tie their ends tightly with a rubber band.
2.Now, put it across the toothpaste tube and again tie it tightly with another rubber band.
3.And guess what you are done!!!
Keep moving it a bit forward to bring out the toothpaste.(see the above pictures)
Here is a tip- Use rubberband as small as possible as they bind it more tightly.
Step 3: Thanks
In the End I thank you for reading my instructable and hope you liked it and would try as soon as possible.
Comments and improvements are always welcome.Please comment and tell me your views.
Thanks again and happy ToothBrushing!!!
