Introduction: How to Make a Wounded Pumpkin?
I'm not one of those fancy jack-o-lantern carvers, so I figured I would just add some twitch on mine.
Step 1: Supplies
The idea is for a water pump to feed colored water via some tubing and out of the pumpkin's wound. The supplies needed are as follows:
  • Red food coloring
  • Outdoor fountain pump
  • ID tubing
  • Halloween tray
  • The star of the show (pumpkin)
Step 2: Cutting Out the Pumpkin!
I bet everyone already knows this part. I tried to do some sketches on paper and opted for this simple design.
Step 3: Preparing the Tray
The pumpkin will be placed on this tray, which sits on top of the reservoir. I drilled a series of holes that would drain the colored water back into the reservoir.
Step 4: Connecting the Pump
First, you need to cut the tubing to the correct length. Next, press and fit it into the pump. You then need to drill a 1/2" hole through the lower back of the pumpkin and run the tubing through.
This would be the source to the blood magic later.
Step 5: Stab the Star of the Show
You can use anything you want, but I used a small drill bit just to make a small exit hole for the "blood." Good thing you don't need to use a drill since you can just spin the bit with your hand.
Step 6: Setting Up the Reservoir
Now the tricky part of this project was somehow trying to find a perfect bowl! After running through a bunch of stores, I finally got one!
Step 7: Fire It Up!
We need a fire for the Jack-O-Lantern, but for this one, we'll just use some 12-volts battery-powered LEDs that you can buy from a local store near you.
Step 8: Now's the Time to Add Some Decors
For the decor, I stuck a knife near the wound hole for additional effect. I also added a "beware" sign on the bowl.
I still have not colored the water, as you can see in the picture.
Step 9: The Final Wounded Pumpkin
Now's the time to color the water red and start turning everything on. And there you have it—simple decor for your Halloween.
Thanks for reading, and I hope you enjoy it.
