Introduction: How to Make an Electroscope!!
Hello, I am an 8th grader who is Famously known for my Gravity-car project!! This time, we'll make an electroscope. I hope you have a easy time making this for your science project and pass it!!
Supplies:
-Cardboard -A Glass Jar -Wire -Electrical Tape (Black) -Aluminum Foil -Straws -Scissors -Styrofoam -Fabric
Step 1: Step 1: Cut a Pear (Aluminum Foil)
For your first step, get your aluminum foil. I want you to get your scissors and cut 2 little pears that are the same size.
Step 2: Step 2: Poke a Little Hole.
Next, you are going to get your scissors and stab a little hole by the top of your little pear.
Step 3: Step 3: Make a Spiral Out of Your Wire.
Get your wire and make a spiral at the top.
Step 4: Step 4: Get Cardboard and Cut a Circle That's As Big As the Hole of Your Glass Lid.
Cut your cardboard and make it as big as the top of your glass jar.
Step 5: Step 5: Stab a Hole in the Center.
Get Your Scissors and stab a hole in the center, in which, a straw could fit through.
Step 6: Step 6: Cut Pieces of Your Electrical Tape.
Cut 4 strips of electrical tape that are the same size.
Step 7: Step 7: Stick Them on Each Side of Your Cardboard Circle.
Stick the electrical tape on the North, West, East, South of your cardboard circle.
Step 8: Step 8: Stick Your Spiral-y Wire in the Straw.
Stick the Wire in the straw. Make sure it fits perfectly.
Step 9: Step 9: Add a Hook
Make a hook at the bottom.
Step 10: Step 10: Stick a Pear.
Put a pear and hook it carefully without breaking it.
Step 11: Step 11: Tape It Down.
Tape the whole thing down.
Step 12: Step 12: Bend the Wire
Bend the wire 90 degrees.
Step 13: Step 13: Get Styrofoam.
Get a fabric and rub it on Styrofoam. The aluminum foils repel from each other.
