Introduction: How to Make an LED Light Box of Your Own
Hi my name is Wehazit Kelati and i go to to school her in Greeley Colorado and i am currently a sophomore in high school. I did this project for my Introduction to technology, class and I decided to write an instructable and I will include the basic steps into creating this LED light box. Just make sure to follow these steps and you will create your own personal Light box.
- Material:
Step 1: Step 1: Materials
Materials:
- Arcylic 3 mm thick
- Ruler to measure out sides
- Laser Machine
- Ultimaker 10s pro 3D printer
- PLA plastic
- Rosin core solder
- Iron
- Rework rosin core
- Heating gun
Step 2: Step 2: Designing and Printing the Box
Designing:
Light box:
- Go to tinkercad.com
- Make a new design
- Create a box wit X,Y,Z as 120mm x 40mm x 30mm
- Make it hollow subtracting 3 mm to the X,Y,Z
- Make a lid using the same measurements
- A wall thickness of 1.5mm
Slot:
- 97,7,40 as XYZ
- Another slot with measurements of 95,4,40 for XYZ and make it a hole
- Align the first slot in the center of the box and move 10 times to the side
- Align the slot hole to the center of the box and move 10 times to the side
- Group them
Circle hole:
- 3,3,20 as XYZ with 20 elevation
- Move to the opposite of the slot and place it to the very side of the box
- Group it
Box hole:
- 13.5,10,20 as XYZ with elevation of 20
- Align it to the center of the side of the smaller side of the box
- Group it
Printing:
- Click on one of the designs
- Click "Import" on top right
- Download as STL
- Do the same with the other design
- Use PLA plastic to make the box
- Make sure everything is good and print using a creality printer
Step 3: Step 3: Elecetronics and Wiring
Electronics and Wiring:
In this step we created a circuit diagram and wired the components to make the box light up.
- Go to circuit diagram maker website
4 electrical components:
- Energy source (AC/DC)
- Conductor (wire)
- An electrical load (Device)
- Controller (Switch)
- Battery
(Each component's symbols are above with the pictures)
Using these four components make a circuit diagram like the one above.
Soldering:
- Heat up the rework solder up to 350 degrees
- Get a 2 3 inch wires and cut half an inch
- Twist the cut wires together so the circuit can flow
- Using the iron melt the silver rosin core and spread it around the twisted part to keep it from coming apart.
- Cut enough of heat shrink tubing to cover the twisted wires
- Put the tube in and melt it to insulate using the blowing heat.
Step 4: Step 4: Acrylic Engraving
Photo Engraving:
- Go to google draw
- choose a picture of choice
- Go to file, page set up, and use the standard 4:3 template
- start tracing the picture using the curved line
- make sure to connect the lines so the shape can come out better
- After tracing remove all the borders
- download as PDF and I sent it to the teacher
Cutting:
Adjust the standard focus of distance so that it it can be closer to the lens by .030" so, it will produce a better edge quality on 1/4 acrylic and thinker. The two types of acrylic are cast and extruded acrylics. The cast will help a better option when engraving which makes a frosted look when engraved. while extruded acrylic can get you smooth edged cutting.
cut a 1/8" (3mm)
- 5000 f (DPI )
- 15s and 100p
you will need a 300 PDI50
watts Epilo Laser machine
1/8'' (3mm) acrylic
Print picture using the Laser Machine printer
Step 5: Step 5: Assembly
Final Product:
The final step is putting all this together to make the box light up!!!
- Get 2 wires
- cut half an inch from the wire
- get a charger block
- cut off the end and 3 inches
- separate the charger wires and cut a]half an inch off
- put the 2 wires in the circle hole
- using the switch put both the cut wires in the circle part and connect them together
- using the solder and iron melt the solder into the wires and switch
- using the solder melt it to connect the LED and Black (Negative) wire on the silver part
- after soldering, using super glue put the whole led in the slot
- Plug in the charger block and it should work.
