Introduction: How to Rebuild Injectors
In this instructable, I will teach you how to remove, rebuild and reinstall injectors.
Step 1: Removal
To rebuild Injectors, you must first remove them from the vehicle. This will reuire a 10mm socket, a 19 mm wrench and a 24mm socket and an impact or ratchet. Remove the intake, injector lines and hold down nuts. After this, pop out the injectors and move on to the next step.
Step 2: Injector Tear Down
The next step is tearing down the injector. to do this, clamp the injector body in a vice. next take a 13 or 15 mm wrench(depending on injector style) and loosen one half of the body. Remove the nozzle, and all internal parts. Move to next step.
Step 3: Reassemble Injectors.
When reassembling, install all new internals, and tighten the injector body. Have a shop pop-test the injectors, or buy your own and do it yourself. Once the injectors are set to where they need to be, you can begin reinstalling.
Step 4: Reinstall the Injectors in Pickup
To reinstall injectors in the pickup, reverse step one. Tighten hold down nuts to 45-50 lb. ft of torque. Bleed injector lines, and enjoy!
