Introduction: How to Replace Fridge Defrost Timer
Replacing the fridge defrost timer is an quick and easy fix. However, prior to doing the actual repair, it's important to disconnect the fridge from the power source to avoid an unpleasant shock.
Step 1: Tools Required
- 1/4 Inch Nut Driver
- Philips screwdriver
- Flathead screwdriver
- Putty Knife
- (2) 1 1/4-inch slot head screws
Step 2:
The fridge defrost timer is
located on the right side of the control housing. To make the necessary
repairs, you will need to access the components within the housing. Using the
1/4-inch nut driver, remove the two quarter-inch hex head screws located at the
rear of the control housing. The hex screws should have two large washers
attached to them, so be careful to keep them together when setting the screws
aside.
Step 3:
Next, remove the two
control knobs and set in an easy-to-find place. To access the inside of the
control panel, we'll need to take off the remaining two hex head screws which
are located behind the escutcheon or face plate. The escutcheon is secured to
the control housing by tabs. Slip the putty knife behind the escutcheon and
gently pull forward, all the while being mindful of the tabs. You don't want to
break them.
Step 4:
After you have detached the
escutcheon, support the control housing with one hand while removing the
remaining two quarter-inch hex head screws with the nut driver. Like the
others, these screws have washers attached, but they are much smaller. Set them
aside. Carefully lower the control housing while avoiding pinching the
capillary tube that controls the coldness of the fridge or breaking the damper
control, both of which runs along the sides of the housing.
Step 5:
The frost timer for the
fridge is located on the right side of the control housing. It's secured in
place with two tilt screws. Remove them using the Philips screwdriver and then
disconnect the four-pin plug attached to the defrost timer. Make special note
of the colors of the wires. You'll need to compare them to the manual that
comes with the timer kit to ensure you have the right part for the make and
model of the refrigerator you're repairing.
Step 6:
Locate the timer mode wire
and terminal, and then force the wire over the speed terminal. Afterwards,
connect the new fridge defrost timer to the plug. Press firmly to ensure a snug
fit. If your previous timer used Philips screws, you'll need to replace them
with the 1 1/4-inch slot head screws. If necessary, enlarge the holes a little
to accommodate the size of the screws.
Step 7:
Line up the holes in the
new timer with the ones in the control housing and insert the screws. Once
inserted, put hex nuts on the ends and then tighten the screws with the
flathead screwdriver. There is no need to use a socket. Holding the nuts with
your fingers as you tighten the screws should be good enough.
Step 8:
To finish up the repair,
realign the control housing and screw in the two quarter-inch hex head nuts
with small washers to secure it in place. Replace the escutcheon, starting with
the bottom and then the top. Put the knobs back in, and then screw in the last
two quarter-inch head screws with large washers. Your repairs are complete. Learn how to troubleshoot problems with your refrigerator's defrost timer at PartSelect.
