Introduction: How to "Salt Out"
Salting out is a process that can be used to dehydrate Isopropyl alcohol, i.e., separate it from water in an azeotropic solution. Dehydrated Isopropyl is useful as a fuel by itself and in helping to determine the right amount of catalyst to add when making bio-diesel fuel.
Removing water also increases the Isopropyl alcohol's ability to:
> melt ice off your frozen windshield
> dissolve water in gasoline
> burn cleaner when used as a standalone fuel
> provide your pet with an invigorating rub after his next bath, which is curiously strong enough (dry enough) to dislodge stubborn ticks and fleas
> serve as a powerful pet or human wound antiseptic
> wash out those wax filled ears
> save you big $$$ (dough, ka-ching, moola, etc.) think money*
(*99.9% Isopropyl Iso-Heet at auto stores runs around 18.25 cents per ounce. 99.9% Isopropyl made from salting out 50%-91% generic retail brand Isopropyl runs around 6.73 cents per ounce. That is a savings of over 63%. If you use it to dry your gasoline then be sure to remove the residual salt using the addendum method.)
What you need:
- bottle of 50% to 70% Isopropyl alcohol
- a wide mouth glass jar and lid, or other leak and Isopropyl proof container
- a pound of non-iodized table salt
- a turkey baster with a reduced size nozzle
- an empty bottle equal in size to the bottle of Isopropyl alcohol.
What you need:
Step 1: Start by Adding the Table Salt
Fill the empty jar about 1/4 full with table salt
Step 2: Add the Hydrated Isopropyl Alcohol
Fill the jar about 3/4 full with hydrated (50% to 70%) Isopropyl alcohol
Step 3: Shake Contents Vigorously
Put the lid on the jar, close to seal the contents and shake jar vigorously to be sure the salt and water combine.
Step 4: Let Gravity Separate the Contents
Place jar on a level surface long enough for the alcohol and salt water to separate (15 to 30 minutes).
Step 5: Keep the Two Layers Separate
Open jar carefully so as not to remix the two layers.
Step 6: Extract the Isopropyl Alcohol
Use the turkey baster to extract the top layer, which will be the Isopropyl alcohol.
Step 7: Fill the Receiving Bottle
Fill a receiving bottle with the turkey baster Isopropyl contents.
Step 8: Label Bottle
Label the bottle "Dehydrated Isopropyl Alcohol"
Step 9: Use Your Dehydrated Alcohol
Use in an alcohol stove, lamp, torch, etc. or to give your pet a nice alcohol rub down.
Step 10: Addendum
You may find that your salted out Isopropyl leaves a salt residue when it is burned. In many applications like a pocket stove the salt residue will continue to serve in the role of helping to separate the Isopropyl and the water when water intrusion occurs from dampness, rain or boil overs.
In other applications the salt residue may not be desired. To separate the salt residue from the Isopropyl use a homemade still. In this case your are not distilling an azeotropic solution of Isopropyl and water but rather separating a liquid from a dissolved solid.
The diagram below illustrates the required components for such a still.
