Introduction: How to Sew a Pillow
About: All things do it yourself
Hey, today I'm going to show you how to sew together a small pillow enjoy
Step 1:
You will need:
-Stuffing
-Old clothes you're allowed to cut up
-Scissors
-Cotton
-A needle
Step 2: Cutting the Fabric
Cut a small square with your scissors
Step 3: Do the Same
Get a texter you can draw on clothes with. Trace around your first square and then cut that out. Now you have 2 squares.
Step 4: Sewing Part 1
Get your needle and cotton and cut a small amount of cotton. Thread it through your needle and pull it up till it is halved. Tie a small knot at the end.
Step 5: Sewing Part 2.
If you want a little design on your pillow, then cut out some more fabric. Get the first square and put your dot on it.
Step 6: How to Sew
Hold your dot and turn your square over. Poke your needle through the bottom and pull up through the top until you feel the pull of the knot. Poke your needle down from the top and pull it out of the bottom till you feel the knot.
Step 7: Repeat
Do this again until you have covered the whole perimeter of your circle.
Whne you have finished sewing a dot, turn your material over and tie a know in the cotton. Then cut just above the knot
Step 8: Sew It Together
Put your first square over the second one and thread some new cotton into your needle. start sewing the sides and the bottom. Do not sew up the top.
Step 9: Stuff It Up
Once you've sewn your sides together open it up and start putting in some stuffing. Stuff until full. After you've stuffed it pull together the row and and sew that up.
Step 10: Done!
Congrats! You have your pillow. If you liked this tut, please follow and comment :)?
Step 11: If You Made a Big Pillow..
If you made a big pillow, this would probably be the max size if you went for really big. To make this you just follow this tut but you can adjust the the size you cut your fabric.
Happy making!!
