How to Sharpen a Drill Bit
Intro: How to Sharpen a Drill Bit
Video tutorial on how to sharpen a drill bit. After usage a drill bit can either dull or chip which does not make it cut as efficiently as it should. A drill bit can be resharpened to make it functional again, there is no need to throw it away. Even broken drill bits can be resharpened. This tutorial applies to a standard style drill bit. Make sure you wear safety glasses when doing this procedure. A drill bit angle gauge can be used, but is not necessary. The more practice you get, the better you will become at sharpening drill bits. I do this by free hand, no special tools are required for the procedure.
Tools/Supplies Needed:
- bench grinder
- square
- drill bit
- safety glasses
STEP 1: Procedure
A drill bit should have a cutting/leading edge angle of 59-60 degrees. Use a square to ensure that the center point of the bit stays centered using a square. The cutting/leading edge should be the closed surface to the material you are cutting and the relief area/trailing edge should be angled at least 5 degrees back from the cutting/leading edge. This maximizes cutting efficiency, reduces heat, and ensures the drill bit works correctly. Be careful not to overheat it so it does not wreck the temper of the metal, so dipping the drill bit in water to cool it down can be done or just simply stop once the bit becomes warmer. When sharpening, move the bit along evenly on the grinding wheel which ensures even wear on the grinding wheel.
STEP 2: All Done!
Reinspect the area to ensure the point is on center, all damaged areas are removed from the top, the cutting angle is correct, and the relief cut is also correct. Now you're ready to use the freshly sharpened drill bit!
Stay up to date with my latest tutorials, don't forget to FOLLOW my profile and be sure to check out my YOUTUBE page as well for all your DIY needs.
5 Comments
Kkrr2 1 year ago
roxanne.benn1 8 years ago
I can't believe how many people do not know how to do this my father taught me when I was about 7. I used to have to sharpen bits for mechanics at a shop I worked at most of them didn't know either. Thanks for sharing I know it will help others.
pfred2 8 years ago
I would not worry about wheel wear. You can always dress a worn wheel back to a proper surface. I frequently dress grinding wheels just to expose fresh cutting surface anyways. That's the first mistake most folks make right there. They try to use worn out grinding wheels. Then they're done before they even start.
I split points on drills I sharpen too. Sometimes it is tricky, and I end up messing up a cutting edge, then I have to go back, and sharpen the bit again. But I like how split points drill a lot better than chisel points.
Mindmapper1 8 years ago
wheels wear cos thats what happens to grinding discs. Yes you should dress them and the ones in the pictures do need dressing. Also always inspect a wheel for damage cracks etc because they make a hell of a mess when they go bang!
BeachsideHank 8 years ago
I hand sharpen also, the final check to verify centering of the point is to drill a piece of scrap, if the chips ejected from the spiral are equal, you're done. ☺
