Introduction: How to Tie Die Fabrics With Sharpies
this is an easy way to tie die fabrics! I hope you enjoy this project.
You will need… rubbing alcohol, some different colored sharpies, white fabric, a rubber band or clothespin, and a bowl.
Step 1:
Take your white fabric and fold it in half. Then fold the two top corners to the bottom corners. Then Fold it in half again.
Step 2:
Put the rubber band or clothespin on the folded fabric. Then use your sharpie to color the edges. Remember to do the bottom too! (I forgot to color the bottom once and it did not turn out that good)
Step 3:
Put the rubbing alcohol in the bowl.
Step 4:
Soak the fabric in the bowl.
Step 5:
wash it with warm water. Then let it dry
Step 6:
You can open your fabric up! You are finished with your project!
