Introduction: How to Tie a Tie by Konrad Holland and Emmanuel Youngblood
This is a tutorial about how you can tie a tie.
Step 1: Step 1
You first must have a button down, collared shirt on. Put the collar up and place the thick part on your left side and the skinny part on your right side.
Step 2: Step 2
First make sure that the thick side is longer than the skinny side. Then crossover the skinny side with the thick side.
Step 3: Step 3
Bring the thick side under the skinny side and then over the top again. Then bring it under one more time.
Step 4: Step 4
After you bring it over, you put it under the knot and then over the the knot. Next put it into the outside loop of the knot.
Step 5: Step 5
Then adjust the tightness. To do this you can hold the knot while you pull the skinny part.
