Introduction: How to Use Joystick_HW504 With "skiiiD"
Before start, there is a basic tutorial for how to use skiiiD
https://www.instructables.com/id/Getting-Started-With-SkiiiD-Editor/
Step 1: Launch SkiiiD and Select Arduino UNO
#1 Launch skiiiD and select New button
#2 Select ①Arduino Uno and then click ②OK button
Step 2: Add Joystick Component
#1 Click '+' ADD button to search and select component
#2 ① search Joystick on search bar and ②Click Joystick Module,
#3 then you can see ③ pin indication. (You can configure it.) #4 ④ click ADD button
Step 3: Four Functions of Joystick
#1 Original skiiID library provides 4 functions
1) getHorizontalData - Indicates Horizontal position of Joystick Module as the numeric value (range : 1~10) .
EX) If Joystick is on the far left position, it will be 1 on the serial monitor, vice versa.
2) getVerticalData - Indicates Vertical position of Joystick Module as the numeric value (range : 1~10) .
EX) If Joystick is on the far down position, it will be 1 on the serial monitor, vice versa.
3) getPosition - Indicates position of Joystick Module as the numeric value(see picture on right)
4) isClicked - Indicates states of Joystick is clicked or not.
