Introduction: How to Use the Processing IDE With Arduino
About: I hold a Master's degree in Computer Science and currently teach STEAM-STEM and ICT. My focus is on making technology and engineering concepts accessible to students through hands-on projects. I teach topics l…
welcome back. Today we will learn to On and off an LED bulb using the processing IDE. For that, we mainly need the Arduino IDE and Processing IDE. We all know about Arduino IDE. But, Processing IDE is a new thing to our blog. Are you a new member of my blog? Please go to the previous posts and read them. OK, let’s look at today’s post. The first time, we will learn what is the Processing IDE.
What is the Processing IDE?
Processing IDE is simulation software. This software began development in 2001. Also, this software mainly focused on visualization technology. You can use this software for game development, robot development, research, etc. Also, we can do 2D and 3D simulations using this software. Examples are drone simulation and flight simulation. However, we need the Java programming language to work with this processing IDE. But, Java’s basic knowledge is enough to work with this software. OK, now let’s go to install the processing IDE on your computer. Let’s do this step by step.
Step 1
The first time, download a suitable version for your computer using this link. — Download
Step 1:
Step 2
Then, extract this zip file to a location of your choice.
Step 2: Components
  1. Arduino Nano board x 1
  2. LED bulb x 1
  3. Jumper wires
  4. Breadboard x 1
Step 3:
Step 1
First, let’s identify these components.
How to use the Processing IDE with Arduino
Step 4:
Step 2
Next, connect these components using the circuit diagram below.
Step 5:
Step 3
Now connect this Arduino Nano board to your computer using the USB cable. Let’s look at the code below.
/*LED on and off using the processing IDE.
void setup() {
Serial.begin(9600);//enable serial communication
pinMode(2, OUTPUT);//define arduino pin
void loop() {
if (Serial.available() > 0) {//check serial value
char led = Serial.read();//read serial value
if (led == '1') {//check serial read
digitalWrite(2, HIGH);//LED on
} else if (led == '0') {//check serial read
digitalWrite(2, LOW);//LED off
Download this code — Download
This code is very easy. The first time enabled serial communication to connect the processing IDE. Then, the second pin is set as the output pin. After using an if condition, the serial communication value is checked to see if it is 1 or 0. Finally, if the serial value is 1, an LED bulb is turned on and if the serial value is 0, the LED is turned off.
Step 6:
Step 4
Now, select the correct board and port. After, click the upload button.
Step 7:
Step 5
OK, now let’s look at the processing code.
  1. The complete program of this project – Download
The second time uploads this code.
Read the code below and use it for any of your creation
import processing.serial.*;//import serial communicate library
Serial myPort;//create serial object
int circleOneX, circleOneY; // Position of button one
int circleX, circleY; // Position of button two
int circleOnesize = 90; // Diameter button one
int circleSize = 90; // Diameter of button two
color currentColor, baseColor;//color variable
color circleOnecolor, circleColor;//color variable
color circleOneHighlight, circleHighlight;//color variable
boolean circleOneOver = false;
boolean circleOver = false;
PFont f;//font type
void setup() {
size(300, 200);//screen size
circleOnecolor = color(0);//set colors to variable
circleOneHighlight = color(51);//set colors to variable
circleColor = color(255);//set colors to variable
circleHighlight = color(204);//set colors to variable
baseColor = color(102);//set colors to variable
currentColor = baseColor;
circleX = width/2+circleSize/2+25;
circleY = height/2;
circleOneX = width/2-circleOnesize+15;
circleOneY = height/2;
printArray(PFont.list());//print fonts list your computer
f = createFont("Ebrima Bold", 20);//Enter your font name
textFont(f);
String portName = "COM4";//Enter your COM port
myPort = new Serial(this, portName, 9600);//select first port
print(portName);
void draw() {
update(mouseX, mouseY);//main method
background(currentColor);//background color
if (circleOneOver) {
fill(circleOneHighlight);
} else {
fill(circleOnecolor);
stroke(255);
ellipse(circleOneX, circleOneY, circleOnesize, circleOnesize);//drow circle one
if (circleOver) {
fill(circleHighlight);
} else {
fill(circleColor);
stroke(0);
ellipse(circleX, circleY, circleSize, circleSize);//drow circle two
textAlign(LEFT);
fill(255);//black color
text("LED OFF", 37, 110);//display text
textAlign(RIGHT);
fill(0);//white color
text("LED ON", 255, 110);//display text
void update(int x, int y) {
if ( overCircle(circleX, circleY, circleSize) ) {
circleOver = true;
} else if (circleOneOver(circleOneX, circleOneY, circleOnesize) ) {
circleOneOver = true;
circleOver = false;
} else {
circleOver = circleOneOver = false;
void mousePressed() {
if (circleOver) {
currentColor = circleColor;
myPort.write('1');//send value one
print("LED on");
currentColor = circleOnecolor;
myPort.write('0');//send value ziro
print("LED off");
boolean circleOneOver(int x, int y, int diameter) {
float disX = x - mouseX;
float disY = y - mouseY;
if (sqrt(sq(disX) + sq(disY)) < diameter/2 ) {
return true;
} else {
return false;
boolean overCircle(int x, int y, int diameter) {
return true;
} else {
return false;
  1. Download this code — Download
Please remember to change the COM port on which your Arduino board is connected.
This code is based on the Java language. please read this code carefully and understand it. So finally, run this code and check your project. To do this, click on the LED on and LED off buttons in the UI (User Interface) we created.
OK, enjoy this project. The full video guide is below. So, we will meet in the next post.
Have a good day.
Bye-bye.
