Introduction: How to Brew Coffee With a K-Cup Without the Keurig Coffee Maker
When we had this coffee maker at my office, it would make really weak coffee, so I came up with this modification so I could make a stronger/free cup of coffee.
(depending on your time, space, and skills).
Requires:
- K-Cup flavor of choice (You can modify this with most single-serving coffee makers with built-in filters)
- 2 cups (alternate method available if you only want to use one cup)
- Scissors
- Hot water tap
Requires:
- Scissors
- Hot water tap
Step 1:
Remove the foil from the top of the k-cup and dump the coffee into one of the coffee cups. You can also substitute or add any coffee grounds at this point.
Step 2:
Using scissors, cut the bottom 1/4 of the cup off.
Step 3:
Fill the cup that contains the grounds with hot water. Some automatic coffee makers have a hot water spigot on the side, others might have a hot water option. Needs to be hot enough to brew the coffee. Leave this to steep about 2-4min.
Step 4:
Holding the top of the k-cup over the second coffee cup, slowly pour the cup with the brewed coffee through the filter. This will remove the grounds.
(Alternate method is to leave the grounds in the k-cup and slowly pour the hot water from the spigot through the k-cup. This takes longer and it is easier to spill over this way.)
Step 5:
Add desired creme/milk/soy/etc and enjoy.
