Introduction: How to Hollow Out a Lightbulb and Make a Stand for It
for other uses like plasma globes and aquariums
Step 1: Materials
for this you will need;
lightbulb (preferably burnt out)
scrap wood block
wire hanger
salt
tools;
wire cutters
duct tape (or stapler or staple gun)
drill
scrap wood block
wire hanger
salt
tools;
wire cutters
drill
Step 2: Remove Brass Contact, Black Glass, and Stuff
use pliers to pull off the brass contact
then use pliers to chip away the black glass
drill the inside of the glass to remove the filament thing and remove sharp glass
Step 3: Clean Out the Bulb
empty out the shards
put a spoonfull of salt in the bulb, cover the opening with your thumb, and shake
empty out the salt, fill halfway with water, cover the opening with your thumb, and shake
Step 4: Now for the Stand
cut a long piece of wire from the hanger
wrap the end of it it around the screw on the bulb
about two inches from the bulb bend the wire down 90 degrees
five or six inches from that bend bend it to be horizontal then two inches from that bend it right 90 degrees
staple or duct tape it to the board
Step 5: Finished
the stand is strong enough to hold the bulb when it's filled with water
you can put a guppie or feeder fish in it (picture soon, i have to find it)
this site gave me the idea for the bulb (and has better pictures)
http://www.teamdroid.com/diy-hollow-out-a-light-bulb/
