Introduction: How to Insert a USB Drive
This type of USB plug is a “USB A”. there are several types of USB cables, I will be focusing on the USB-A cable.
The purpose of this instructable is help you not be so frustrated when plugging in your cables and drives. This is for the people who bend over and peer into their drive ports and then peek into their USB plugs followed by some
slight sweating while hoping you are plugging it in correctly. The frustrating thing is, you are usually right, but because you lack the confidence to push a little harder and not hurt your plug, you flip it over a few times before getting it inserted correctly.
Turns out, there is a trick to knowing which way to plug it in!
I have found that there are rare circumstances where this trick doesn’t work. With your new found skills and confidence you will find those rarities easily!
If you love this instructable, please don't forget to vote!
Step 1: Look for the USB Symbol or Flash Drive Logo
Examine your USB cable/drive and notice that one side has the USB symbol imprinted into them or a logo for the flash drive of some sort. Everyone once in a while you will find a drive or cable without either, but they are usually older. This is the top of the drive/cable.
Step 2: Look for the Side of the Cable or Drive With the Seam
Examine your USB cable/drive and notice that one side has a seam. It looks like the metal was folded over and this is where they joined together to make the box. This is the bottom of the drive/cable.
Step 3: Plug It In, Top Side Facing You
Plug in the drive, cable with the USB logo facing you.
Viola! You are a genius and you did it with confidence.
