Introduction: How to Make a Duck Tape Laptop Computer Sleeve / Cover
I was in need of a laptop sleeve for my computer but wanted to construct my own. this is how to make one easily on a cheap budget.
Materials:
1. 2 rolls of duct tape different colours recommended
2. Sharp knife or scissors
3.place for cutting e.g. cutting board
4.laptop for measurement
Step 1: Duct Tape Sheet
Take the width and length of your computer
start constructing a duct tape sheet.
a duct tape sheet is made by laying strips of duct tape next to each other adhesive side up with no space between than placing another strip in the middle of those pieces adhesive side down. Repeat this process making sure the length is larger than the computer.
Also when constructing this try alternating the colours of the tape in order to give a nice pattern I used blue and black.
Step 2: Duct Tape Sheet
make the sheet so it is double the length of the laptop from front to back find the centre strip and reinforce the base for strength.  Once you have made the sheet so it can completely cover the laptop do a couple more strips as a cover / lid for the sleeve, so it over laps the other side.
Step 3: Sides
to clean up the sides of the duct tape sheet, place a strip of tape on the edges with some adhesive exposed than fold over to give a nice look
Step 4: Sides
Place your laptop on the sleeve and fold the side so the computer fits snug than remove the computer and tape the sides closed than tape the inside edges of the sleeves also for strength.
I found the top flap became larger than the case as i had folded the sides in so, I trimmed it a little to fit.
Step 5: Lid / Cover
edge the top the same way as the sides to give a nice clean look.
Step 6: Optional Handle
the handle is optional i did not make one but is easily done.
chose the size you want your handle and attach a strip of tape to the inside edges of the bag withe the adhesive side out than attach a piece to the outside attaching it to the other strap you can reinforce it as much as you want for strength.
do not attach to lid as the lid is flimsy and is not supportive enough.
Step 7: Results
here are some result pictures from my bag.
