Introduction: How to Make a Flashdark!
In this instructable I will tell you how to make a flashdark. What is a flashdark, you may be asking. Well it's basically a flashlight, but instead it's a flashdark!
Step 1: MAterials
What will I need to make a flashdark, you ask? Well can't you see the name of this step is called materials?
1. A flashlight that takes batteries.
2. Gypsie dust (optional).
3. Some sparkles (optional).
Step 2: The Flashlight
Ok so now is the part where your screwed if you haven't found a flashlight yet! If you have it, pick it up right now. Study it, and continue on to the next step!
Step 3: Battery Cover
Ok, so now your wondering what to do, right? WELLLLLLL you need to remove the battery cover, if you don't remove it then this instructable will be a waste of time... After the battery cover is off, take out the batteries/battery I can't stress this enough. When I first made this flashdark, I accidentaly took the batteries in... Big mistake... Don't Make the same mistake I did.
Step 4: Time to Make It Dark!
Now that the batteries/battery are/is out, put them in but instead of the right way put them in the wrong way!
Step 5: Put the Battery Cover Back On
The name of the step is self explanatory!
Step 6: Work It!
All you have to do to work your new flashdark 3000 is click the button, and. *BAM!*
-Warning I am not liable for any injuries caused by the flashdark 3000, results may vary-
