Introduction: How to Make a Simple 3D House
I will use---> Illustrator , Rhino and Afinia 3D printer to make the house
This houses are designed by my roommate Minyoung Lee.
Step 1: Sketch Houses That You Would Like to Make
Step 2: Import the Sketches File to Ilustrator
Step 3: Import the Illustrator File to Rhino
Step 4: Made a Body
1. Click the body part in sketch --> (Command): ExtrudeCrv
2. Cap the Extrusion ---> (Command): Cap
Step 5: Put Windows
<Engrave window>
1. Make widows to 3D that you would like to engrave on the sketch ---->(Command): ExtrudeCrv + Cap.
2. Engrave the window part form Body ----->(Command): BooleanDifference
<Add window>
2. Add the window part form Body ----->(Command): BooleanUnion
Step 6: Cut Unnecessary Part
1. Draw line on the part you would like to cut.
2. Cut the part through the line you drew ---> (Command): Split
Step 7: Cover the Cut Part
If you can't cover it with Cap (command) then ------>(command): Loft and click the part that you want to cover
Step 8: Add Basic Shape on the House
Step 9: Export It to STL File
based on 3D printer you can export it to gcode too:)
