Introduction: How to Make an Entire Ship Out of Paper
Materials required
Loads of tape
Loads of white paper
some black paper or a black marker
Tools
glue gun (Optional)
strong glue
Costs less than 1.5 dollars
Loads of tape
Tools
glue gun (Optional)
strong glue
Step 1: Making the Parts
Roll 500+ tubes from paper
Take a piece of paper and roll it up to form a thing tube of 20-30 cm long and 1 cm wide
Step 2: Making the Walls and the Stairs of the Ship
Join upto 21 tubes and make a semi-oval shape for the front
Join upto 14 tubes to make a rectangle for the back
Join 36 tubes to make the central base with two holes in the centre
Step 3: Completing the Front Walls and the Back Walls
take the semi oval and add tubes (10 tubes) to it on its egdes to form a 3D front wall(use picture for guidance).
take the rectangle and add tubes (10 tubes) on its edges to form another 3D shape(use picture for guidance)
Step 4: Completing the Main Base
Take the big rectangle with 2 holes in it and start adding tubes on the edges add upto 6 tubes height on all sides
Step 5: Making the Base to Keep the Ship On
join upto 100 tubes of 40 cm to make a big rectangle (big enough to keep all the parts on it)
Step 6: Joining the Parts
Join the three parts together and hot glue them and hot glue the whole thing on the base that we made.
Step 7: Making the Rest of the Details
join 3 black tubes and make a triangle and place two tubes on it to make a cannon make about 10 cannons to place all over the ship
Make some paper ladders and put them in the two holes in the centre of the ship
You can also make doors anywhere on the ship you want .
Make 3 fat tubes one long and 2 short ones.
Stick the two small ones on the front and tAttach a sail on the big paper tube and stick it in the middle of the ship
Join the three tubes with strinhg to make the ship look real.
You can add whatever you want and make the ship your kind.
Step 8:
And you are done
You have made your own kind of ship
