Introduction: How to Make Coffee at TechShop
Everyone knows how to make coffee in the comfort of their own home, but industrial coffee makers are a little intimidating when you've never used one before.
This Instructable will have you making coffee with the Bunn coffee makers found in TechShop in no time!
You will need:
A Bunn coffee maker
coffee filters
coffee beans
a coffee grinder
2 coffee carafes
Step 1:
First measure and grind your coffee beans.
I usually start with a cup of unground coffee beans (your tastes may vary depending on how strong you like your coffee)
Once ground, pour into coffee filter.
While you're grinding your coffee beans, fill one of your two coffee carafes with water.
Step 2:
Now place your empty carafe on the burner.
Next, place your coffee grounds in your filter into the coffee filter holder (located just above where the carafe sits)
Step 3:
Next, take your carafe of water and pour it into the water tank opening located on the right side of the top of the machine
Step 4:
Finally, once there is some coffee in the carafe, turn on the warmer so your coffee doesn't get cold.
Once the coffee has finished dripping (when the water stops flowing) repeat the process using decaf coffee!
Enjoy!
