Introduction: How to Make the Perfect Omelet
Making an omelet can be a hard and scary task. This Instructable will hopefully help you accomplish this task. This is a technique I discovered a year ago will cooking. This may be a little extra work but it's worth it.
Step 1: The Supplies
To make this omelet you are going to need:
Non-stick cooking spray
Eggs (I used two but you can use as many as your skillet will hold)
Skillet
Spatula
Zip-Loc bag
Small bowl
Toppings
I used a skillet that was way to big for my omelet. (It was all I had at the moment and I didn't feel like looking for one)
Skillet
Spatula
Zip-Loc bag
Small bowl
Toppings
Step 2: Heat and Spray the Skillet
Spray the skillet with the Non-Stick cooking spray. Heat it on Med-High heat. Make sure it's not too hot or the outside will cook faster than the inside.
Step 3: Prepare Eggs
Crack the eggs into the small bowl. (the bowl is necessary but it make pouring much easier). Pour the eggs into the Zip-Loc bag. Shake and smash the egg yolks until the yolks mix with the whites.
Step 4: Pour and Cook the Eggs
Carefully pour the omelet into the skillet. this is done by opening one corner of the bag.
Step 5: Cook and Add Toppings
Cook the egg for about 1-1:30 mins on one side. Then add the toppings. make sure you don't add to many or the omelet won't cook properly. Wait about 30 seconds then fold the omelet in half covering the toppings. Flip the omelet. Cook for about 1 min then serve. add salt or butter on the top if desired.
