Introduction: How to Repair Frizzy Barbie Doll Hair
In this instructable I will show you how to repair a barbie doll's hair this process may also work on monster high & ever after high. But I'm not sure about China dolls,wooden doll with hair and my little pony!(I'm not sure because I haven't tried this process on wooden dolls,mlp and China dolls!)
Anyways let's get started!!! :D
What you will need:
. Hair conditioner and shampoo
. Body lotion
. Barbie doll (of coarse)
. Normal comb and head lice comb
. Towel (not shown in photo)
. Beaker ( pouring,measuring cup )
What you will need:
. Body lotion
Step 1: Washing the Barbie's Hair With Shampoo
First lay your barbie,head hanging next to a sink,then fill the beaker will water that's close to 100 Celsius (boiling). Then pour over the barbie's hair making sure to not burn yourself(trust me you do not want to get a burn). Then rub in some shampoo( it should look foamy). Then rinse the shampoo out with water(hot or cold is fine).
Step 2: Combing the Barbie's Hair
Lay your barbie flat on a hard surface then take your normal comb and keep combing the hair until the hair is straight and flat( the ends may curl a little and that's ok).
Step 3: Washing the Barbie's Hair With Hair Conditioner
Lay your barbie flat the same way you did when you washed it's hair with shampoo then instead of taking some shampoo take some conditioner and rub it in the barbie's Hair and then wash with water close to 100 Celsius(boiling) and try not to burn yourself it hurts! Then afterwards wash the barbie's hair with cold water. And if you burnt yourself also rinse your burn under the cold water ( it feels good!)
Step 4: Combing the Barbie's Hair Part 2
First comb the barbie's hair for 2 minutes using the normal comb then comb the barbie's hair using the head lice comb until the hair looks like it's thin strips of paper!
Step 5: Drying the Barbie's Hair + Finished
Lay out a towel somewhere and place the barbie flat with its hair sticking straight out beyond the forehead (look at photo because I can't explain it that well!)
Then leave it to dry overnight if it's not dry after that let it dry for longer! Warning: do not blow dry the hair 1. It will make the hair frizzy again! .2 it can melt or burn the barbie's hair,because the barbie's hair is plastic! :)
FINISHED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :^|
