Introduction: How to Use 7 Segment LED Display
About: I am an electrical student living at chennai i love electronics very much.
Hi guys in this instructables iam going to say how to use seven segment LED display. it cost only Rs: 8 ( indian rupee). you can also add this to your project to display numbers or some words also.
Step 1: Components Need
To activate LED's in Display you need some components
* 1 k ohm resistor × 1
* 7 segment display ×1
* 6V Dc supply
Step 2: LT542
There are several type of 7 segment display are avilable in market.I used here is LT 542.
Step 3: Circuit
Pin configuration for seven segment display.
Each side of display contains five pins.The middle pin is cathode which always connected to positive terminal. you can see small dot you can also use that.
Step 4: Working
The positive should connected to cathode. Then the balance are made as per your requirement.
