Introduction: How to Verify an ISBN
ISBN is abbreviation of International Standard Book Number, which usually can be found on the back of a book.
This instructable is designed to help people find out whether a ISBN is valid using easy mathematics.
You will only need a pen/pencil, a piece of paper.
Step 1:
Find out what kind of ISBN you have.
Two kinds of ISBN is now used for a book, 10 or 13 digits.
Usually, a 13 digits ISBN is converted from a 10 digits one by adding a "978" prefix and alter the last digit, which is often called the check digit.
Step 2-4 for 10 digits ISBN.
Step 5-7 for 13 digits ISBN.
Step 2:
In case you have a 10 digits ISBN, for example, the ISBN for the book Gravitation .
0-7167-0344-0
You need to assign the position of each number from left to right.
Step 3:
Multiply each number by its position number and then sum up the products.
Step 4:
Divide the sum by 11 and find out what is the remainder.
If the remainder is zero, then it is a valid 10 digit ISBN.
If the remainder is not zero, then it is not a valid 10 digit ISBN.
Step 5:
If you have a 13 digits ISBN.
978-0-7167-0344-0
Also assign the position of each number from right to left
Step 6:
Multiply each number by an alternating 1 and 3 and then sum up the products.
Odd number positions by 1.
Even number positions by 3.
Step 7:
Divide the sum by 10 and find out what is the remainder.
If the remainder is zero, then it is a valid 13 digit ISBN.
If the remainder is not zero, then it is not a valid 13 digit ISBN.
