Introduction: Hydro Dipping
Hydro dipping, the next big thing. With hydro dipping, you can quickly make custom items. What you will need is very simple.
1. A bucket to hold the water and paint.
2. Your choice of spray paint.
3. A clear coat spray.
4. And if you are taking something apart the required tools to do so.
5. A drop cloth to protect your work space.
Step 1: Step 1: Add Primer Coat and Prep.
You want to add a primer coat to the object you are dipping so the paint has something to grab onto. You also want to prep your bucket or bin of water for the dipping process.
Step 2: Step 2: Dip
You want to angle the project and slowly lower it into the water that has the paint sprayed ontop. after the project is completely under the water move away the access paint and lift the project out. You want to let the project dry overnight to allow the paint to dry.
Step 3: Step 3: Clear Coat
Once the project is done put a protective clear coat over the project. Now you have your very own custom hydro-dipped product.
