Introduction: IC Based Simple 12V to 240V Inverter Using MOSFET & IC 4047
In this tutorial we will show you how to make simple IC based inverter circuit. You can watch the video which is embedded in this step for construction, parts list, circuit diagram & testing or you can continue reading the post for further details.
Step 1: Parts List
2*IRF540
2*Heat Sink with Screw
2*100 Ohm 1*CD4047 or HCF4047
1*14 Pin IC Holder (i am using 16 Pin IC holder)
1*0.1uF Ceramic Capacitor
1*47k Ohm
1*1.2k Ohm
1*LED
1*2 & 3 Pin Terminal Block
1*240v to 12-0-12v Transformer
1*Bulb Holder
***Affiliate Links***
Banggood
IRF540 Mosfet - https://goo.gl/RYauWz
14 Pin IC Holder - https://goo.gl/3Eap4r
Heat Sink with Screw - https://goo.gl/gvAhgN
240 to 12-0-12v 5Amp Transformer - https://goo.gl/eDMmG4
If you wish to support my content, then you can do by using my affiliate links given below, this way i get small commission for your purchases.
Bangood - https://goo.gl/ZUhRmV
AliExpress - https://goo.gl/jioyhV
Amazon USA - http://amzn.to/2u7ztbP
Amazon UK - http://amzn.to/2wu4nYP
Amazon India - http://amzn.to/2hroLHz
Step 2: Circuit Diagram & Other Details
For construction of this project we are using 4047 IC which is an lower power mono-stable/astable multi-vibrator. The circuit is assembled to be a astable multi-vibrator.
The frequency of the circuit is around 50Hz, (You can alter the frequency of the circuit by changing the value of C1 & R1)
The MOSFET's are connected in a push pull configuration which will switch according to the pulse from the astable multi-vibrator. The MOSFET's should be connected to a heat sink.
The transformer is one of the main components which is a normal step down center tapped transformer which is easily available in the market. The transformer is connected in the reverse manner or inverted manner to give a output of 240volt. if the voltage rating in your country is 110v then i recommend using a transformer with the rating 110v to 12-0-12 volt.
The output of this inverter is around 60 watts. The output depends on the voltage & current rating of your battery.
Warning - Please be careful while making this circuit
To watch the test results please watch the video attached in the first step or CLICK HERE
For other variant of the inverter please CLICK HERE. This inverter is purely based on transistor & MOSFET
Thank You for watching
For more such contents please visit & subscribe to my YouTube Channel by CLICKING HERE.
