Introduction: ITTT Controllable Turret
This is an arduino powered knex turret tutorial :)
If you have any questions don't hesitate to ask!
Step 1: List of Items You Will Need:
ARDUINO PARTS:
- 1 Arduino Uno
- 1 breadboard (I use a half sized breadboard)
- 7 wires around 20 cm*
(I used 2 Yellow, 2 Blue, 2 Red and 1 Black.) - 2 wires around 7,5 cm*
- 1 potentiometer
- 1 micro servo
*The color of the wire does not really matter as long as you know which wire goes where. Its just an easy way to look for problems when it doesn't work like it's supposed to. Also the length does not really matter, these lengths are just to make it easier for you.
KNEX PARTS:
- (see the image for the knex parts)
OTHER MATERIALS:
- Cardboard
- Tape
- A tool for cutting (scissor for example
SOFTWARE:
- Arduino (download it at: https://www.arduino.cc/en/Main/Software)
Step 2: [KNEX] Building the Base of the Turret
Items needed in this part of the turret:
KNEX PARTS
- 8 gray rods
- 16 white rods
- 8 blue rods
- 24 green connectors (some of mine are a different green just don't mind that)
- 16 orange connectors (some of mine are black just don't mind that)
- 8 yellow connectors
OTHER MATERIALS
- Cardboard
- Tape
ARDUINO PARTS
- 1 micro servo motor
Step 3: [KNEX] Building the Top of the Turret
KNEX PARTS
- 16 white rods
- 8 blue rods
- 3 red rods
- 17 yellow connectors
- 2 orange connectors
- 4 white connectors
- 12 blue slide connectors
- 8 green connectors
OTHER MATERIALS
- Cardboard
- Tape
ARDUINO PARTS
- 1 servo motor top part
Step 4: [ARDUINO] Setting Up the Wires
As long as you have all the parts and you follow the image above you should be good to go.
To make sure it will work make sure you put the wires on the right places :)
One tip, start by putting in the smaller wires first so the longer ones can go over them, else it can get a bit annoying to connect the wires.
Step 5: [ARDUINO] Writing the Code
Start the Arduino software and write the following code:
include <Servo.h>
Servo myservo; // create servo object to control a servo
int potpin = 0; // analog pin used to connect the potentiometer
int val; // variable to read the value from the analog pin
void setup() {
myservo.attach(9); // attaches the servo on pin 9 to the servo object
void loop() {
val = analogRead(potpin); // reads the value of the potentiometer (value between 0 and 1023) val = map(val, 0, 1023, 0, 180); // scale it to use it with the servo (value between 0 and 180)
myservo.write(val); // sets the servo position according to the scaled value
delay(15); // waits for the servo to get there
Once you have done that you are ready to upload it to your arduino!
Before you try to upload make sure that you have the right USB port selected in the arduino software!
You can find the full tutorial on this code on: https://www.arduino.cc/en/Tutorial/Knob
