Introduction: Installation Guide for Magneti Marelli Module on Fiat Freemont 170 CV AWD
For installation remove the engine cover and search the connector to disconnect.
Unpack the cables.
Unpack the cables.
Step 1: Prepare the Module
Connect the main connector to the additional module.
To prevent any water infiltration isolate the connector. Place the module on the left front wheel arches.
Step 2: Search the Original Connector
Identified the connector using a screwdriver and disconnect using the module connectors additional equivalent practicing bypass
Step 3: Connect Module
The module connector has two additional tabs that obstruct the correct insertion of the connector.
Using a cutter to clear them. insert the connectors and work is completed.
Step 4: Reassemble
reassemble the engine cover.
Installation time 30 min.
