Introduction: Interactive Jewelry Box
This is a jewelry box, made with laser cut baltic birch wood, with a moving dancer, lights (option with no lights for photo-sensitive viewers), music, controlled by a circuit playground bluefruit.
Made by Danielle O'Connor
- Adafruit NeoPixel Digital RGB LED Strip- 30 LED- 0.5 meters
- Adafruit TowerPro SG92R Micro Servo
- Alligator clips
- Baltic birch wood (⅛ in) (optional)
- Circuit Playground Bluefruit
- Glue
- Laser cutter and plans (optional)
- Paint and brushes (optional)
- Tape
Step 1: Make Your Box
You can use any box that you would like. For this project, I laser cut a box using MakerCase, glued it together, and painted it.
The link to the plans I used: click here
Step 2: Set Up Devices
Attach servo and LED light strip to the CPB. Glue the servo to the lid of the box. Tape the LED light strip into a circle that wraps around the bottom of the box.
Then attach your dancer to the top of the servo. I cut a white fabric, placed it over the servo to hide it, and added glitter.
I added two dancers on the side of the box to trigger the dancing but you can use alligator clips + your own object.
Step 3: Write the Code
I attached the code I used to power my jewelry box below. Feel free to use and adjust as you see fit!
Step 4: Use It!
Here is the demonstration video. The dancer on the left shows the dancer with lights and the dancer on the right shows the version for photo-sensitive viewers.
Enjoy!
