Introduction: Arduino Internet Controlled Desk Lamp
About: Hello, I'm Bruce. I'm a student in Belgium. I have a wide variety of interests: electronics, computers, technology, ... In my spare time I spend a lot of time on: projects, exploring the internet, cycling. ht…
This is a little project I did to control my desk lamp over the internet.
Step 1: What You'll Need
A linux web-server with PHP, an arduino, a relay and some other components.
Step 2: Upload Your Code to the Arduino
Upload the following code to your arduino:
void setup(){
  Serial.begin(9600);
void loop()
  if (Serial.available() > 0) {
    char inByte = Serial.read();
    if(inByte == '1'){
      digitalWrite(13,HIGH);
    else if(inByte == '0'){
      digitalWrite(13,LOW);
Step 3: The Circuit
Connect everything as shown in the image.
Connect the base of the transistor to the pin used in the code I used pin 13
Connect your light bulb in series with switching contacts of the relay.
And connect your arduino to your server.
Step 4: The Webpage
php_serial.class.php = Serial library
example.php = The code
make sure you put the path of your arduino on the following line:
$serial->deviceSet("/dev/ttyUSB0");
Upload this two files to your server in the same directory.
Step 5: Test It
Make sure your permissions are right
go to your terminal and type: ls -l /dev/ttyUSB0
then you'll should get a response like:  crw-rw-rw- 1 root .............
otherwise you have to set the permissions type: chmod 666 /dev/ttyUSB0
Browse to the example page.
Normally you should be able to control your lights.
