Introduction: Intro + Supplies for Buzzer Soundboard
This project you will be able to use a remote to make different sounds from the buzzer
download Arduino from:
https://www.arduino.cc/
Supplies include:
Arduino Uno X1 Breadboard X1 Buzzer X1 IR sensor X1 Remote X1 Quick connect wires X9
Step 1: Setting Up the Remote With IR Sensor
first your gonna have top set up and test your remote with a little code that I got for toptechboy.com and dont forget to download the IR sensor library from Arduino
https://toptechboy.com/arduino-tutorial-64-underst...
code sample:
#include //Make sure to install the library
int IRpin=9; IRrecv IR(IRpin); decode_results cmd; String myCom; void setup() { Serial.begin(9600); IR.enableIRIn(); }
void loop() { while (IR.decode(&cmd)==0){ } Serial.println(cmd.value,HEX); delay(1500); IR.resume();
if (cmd.value==0xFF6897){ myCom="zero"; Serial.println(myCom); } if (cmd.value==0xFFA25D){ myCom="pwr"; Serial.println(myCom); }
Step 2: Tinkercad
before going to hard wiring test it in Tnkercad to test out the bugs or even add or remove code
The Code for Tinkercad:
#include
const int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
int buzzer1=2;
void setup(){
Serial.begin(9600);
irrecv.enableIRIn();
irrecv.blink13(true);
pinMode(buzzer1,OUTPUT);
void loop(){ if (irrecv.decode(&results)){
Serial.println(results.value, 0);
irrecv.resume();
Serial.println(results.value);
if (results.value==16593103)
digitalWrite(buzzer1,HIGH);
delay(0);
digitalWrite(buzzer1,LOW);
delay(100); } if (irrecv.decode(&results)){
Serial.println(results.value, 100);
irrecv.resume();
if (results.value==16582903)
delay(100);
Serial.println(results.value, 200);
irrecv.resume();
} if (results.value==16615543)
delay(200);
digitalWrite(buzzer1,LOW); delay(100);
Serial.println(results.value, 300);
irrecv.resume();
if (results.value==16599223)
delay(300);
Serial.println(results.value, 400);
irrecv.resume();
if (results.value==16591063)
delay(400);
Serial.println(results.value, 500);
irrecv.resume();
if (results.value==16623703)
delay(500);
Serial.println(results.value, 600);
irrecv.resume();
if (results.value==16607383)
delay(600);
Serial.println(results.value, 700);
irrecv.resume();
if (results.value==16586983)
delay(700);
Serial.println(results.value, 800);
irrecv.resume();
if (results.value==16619623)
delay(800);
Serial.println(results.value, 900);
irrecv.resume();
if (results.value==16603303)
delay(900);
irrecv.resume();
if (results.value==16597183)
digitalWrite(buzzer1,HIGH); digitalWrite(buzzer1,LOW); } if (irrecv.decode(&results)){
irrecv.resume();
if (results.value==16609423)
digitalWrite(buzzer1,HIGH); digitalWrite(buzzer1,LOW); delay(200); digitalWrite(buzzer1,HIGH); delay(100); digitalWrite(buzzer1,LOW); } if (irrecv.decode(&results)){
Serial.println(results.value, 1000);
irrecv.resume();
if (results.value==16625743)
delay(0);
delay(100); digitalWrite(buzzer1,HIGH);
delay(100);
delay(200);
delay(300);
delay(400);
delay(500);
delay(600);
delay(700);
delay(800);
delay(900);
irrecv.resume();
if (results.value==16621663)
Step 3: Hard Wiring
hard wiring is latterly just taking the Tinkercad wiring and making not artificial.
use the picture above to show you how to wire it
Step 4: Code for Arduino
#include
int buzzer1 = 2;
void setup() {
Serial.begin(9600);
pinMode(buzzer1, OUTPUT);
void loop() {
if (irrecv.decode(&results)) {
irrecv.resume();
if (results.value == 0XFF6897)
digitalWrite(buzzer1, HIGH);
delay(0);
digitalWrite(buzzer1, LOW);
delay(100);
irrecv.resume();
if (results.value == 0XFF30CF)
delay(100);
delay(100);
irrecv.resume();
if (results.value == 0XFF18E7)
delay(200);
delay(100);
irrecv.resume();
if (results.value == 0XFF7A85)
delay(300);
delay(100);
irrecv.resume();
if (results.value == 0XFF10EF)
delay(400);
delay(100);
irrecv.resume();
if (results.value == 0XFF38C7)
delay(500);
delay(100);
irrecv.resume();
if (results.value == 0XFF5AA5)
delay(600);
delay(100);
irrecv.resume();
if (results.value == 0XFF42BD)
delay(700);
delay(100);
irrecv.resume();
if (results.value == 0XFF4AB5)
delay(800);
delay(100);
irrecv.resume();
if (results.value == 0XFF52AD)
delay(900);
delay(100);
irrecv.resume();
if (results.value == 0XFFA25D)
irrecv.resume();
if (results.value == 0XFFB04F)
delay(200);
delay(100);
irrecv.resume();
if (results.value == 0XFFE01F)
delay(0);
delay(100);
delay(100);
delay(100);
delay(200);
delay(100);
delay(300);
delay(100);
delay(400);
delay(100);
delay(500);
delay(100);
delay(600);
delay(100);
delay(700);
delay(100);
delay(800);
delay(100);
delay(900);
delay(100);
irrecv.resume();
if (results.value == 0XFFA857)
Step 5: The End
this what your Finally project should look and sound.
