Introduction: K-POP Stickers
Hi ❤️, so today I'm going to show you how to make K-POP Stickers. #HMS2020
-White paper; Construction paper; or any White paper of choice if not then colored.
-Scissors or A Knife
-Wax Paper
-Clear Tape
Step 1: Choosing/Printing an Image
Pick an image from online or get an image. You can get pre-made sticker design or pick an image to edit. Then print out the desired image. You can use any type of printer but if you wanted to have color you can print it with a colored printer.
Step 2: Cutting Out the Image
Then you are going to cut out the image. You can scissors for more rounded pictures and a knife for straighter edges/pictures. While your're cutting to picture out make sure to leave a bit of space on the edges.
Step 3: Laying Out the Image
Then you take a piece of wax paper it could be the size of your picture or bigger than the picture. After that you are going to take the tape and place a few pieces or a piece for the size of the picture onto the wax paper. Then you are going to take the pictures and place it onto the wax paper with the tape on it. Make sure that its on the wax paper like how you want it.
Step 4: Taping the Image
After that you are going to take the same amount of tape or more. Then line it up with the image and the wax paper. Make sure that there are no air bubbles while you are taping it. You can get rid of the air bubbles with a card etc.
Step 5: Cutting It Out
You can use scissors for more rounded edges and a knife for straighter edges. When you are cutting it you want to leave a bit of extra space around the picture. Also, leave a little tab on the side of the picture to peel it later.
Step 6: Conclusion
Then you should be done with it! Also, make sure to rip or take all of the wax paper. If you wanted your picture to get the shape then you could cut around the whole picture and not have the tab. The wax paper can sometimes also stick onto the picture so you need to carefully take it off. Sometimes the tape can peel apart.
