Introduction: K'NEX Marble Chain Lift /w Instructions
About: I like to build with K’NEX as you can find many things I’ve built here. I also love to watch YouTube videos, have played piano and drums for over 10 years, listen to music (not country), and play video games (…
Have you ever built any marble contraptions as a kid? Have you ever seen other people's marble machines and saw that some of them have lifts (like on YouTube)? Well, me too. But now, there's an easy way to make one, so I made this guide to show you how to build a chain lift for marbles instead of just trying to figure out on your own. REMEMBER: Multiple marbles can't go in at once. Inspiration for this comes from amandaallen6 (a YouTube user).
HERE'S the lift IN ACTION:
Here's amandaallen6's video: http://www.youtube.com/watch?v=udUo6ZRawEE
Step 1: Parts List
Before we begin, gather up your pieces kind of like I did in pic. 1, then PLEASE refer to the pics. 2-4 to see what pieces i'm talking about in the list below. I can't be exact on every piece because some of the pieces have different colors I don't own.
Rods
Green- 25
White- 19
Blue- 31
Yellow- 45
Red-49
Gray-15
Connectors
One-way- 9
Two-way Orange- 14
Two-way Gray- 6
Three-way- 47
Four-way- 2
Five-way- 17
Eight-way- 3
Seven-way Blue- 28
Four-way Gray- 47
Other
Gray spacer- 38
Blue spacer- 21
Tan clip- 5
Blue clip- 2
Y-connector- 20
Black Dot- 2
Black Dot Cup- 2
Black Hinge- 2
Blue Hinge- 2
Small blue panel- 2
Tiny blue gear- 1
Medium gear- 7
Chain links (regular)- 78
1 GREEN Motor
Regular (6 mm) marbles
Total: 540+
* + is for the amount of marbles you're using
Now that you have everything you need, lets get to building!
Step 2: The Tower Part 1
This is part the tower the lift will be built on.
Step 3: The Tower Part 2
The other side of the tower which will be attached to the other side (pic.3) in the next step.
Step 4: Attaching the Two Sides
Now, take what you built in steps 2&3 and put it together. Be sure to look at the close-ups.
Step 5: Add Supports
You need this or else it'll fall on either side
Step 6: The Loading Bay
This is where the marbles go to be lifted up by the balls. Be sure to build both things and look at all the pictures.
Step 7: The Motor Section
This is what will automatically bring the marbles up to the top.
Step 8: The Exit Track
This is where the marbles will fall onto from the claws that carry the marbles up.
Step 9: Adding the Two Support Gears
Now, time to add the two support gears to how to chain will move. Be sure to look at all the pictures.
Step 10: Making and Adding the Chain
This is what will be used to bring the marbles up to the top. Look carefully at everything
Step 11: Finished!
Congratulations! You now have your own chain lift for marbles. Now, you can bring your childhood memories back to improve those contraptions with this lift. Turn the "green" motor to the right, load marbles only one at a time and let the fun begin. ONLY USE REGULAR MARBLES!!
