Introduction: Kaktovik Numeral Clock
laser cut clock using Kaktovik Numerals
laser cutter
1/8 plywood
Paint/ brushes
corel draw for separating and use of Numerals
wood glue
clock kit
epoxy resin
Step 1:
laser cut a 10 inch circle
and 9.5x10 inch circle for a resin border.
Step 2:
using Corel Draw separate and save files for laser cutting and cut out the numerals.
Step 3:
using wood glue
glue circle border onto the bottom circle
glue all the numerals into the corresponding spots on the circle
and let dry.
Step 4:
mix epoxy resin to resin specifications and pour
while on a flat surface
and let properly cure.
Step 5:
drill a hole into the middle of the circle to add the clock kit and hands and you have a finished Kaktovik Numerals clock
