Introduction: Kimono Cardigan
I like these kimono style cardigans but often they are quite expensive. This is a cheap option, it is fun to make and recycles unused scarves.
Choose your design and length to suit the style and finish that you want.
Step 1: Materials
- Scarf (180 cm x 53 cm)
- Fabric Scissors
- Tape Measure
- Pins
- Sewing Machine
Step 2: Cutting Out the Back and Front Pieces
Fold the scarf in half
Measure 60 cm from the open end
This will allow you to use the neatened edges as the bottom of the cardigan
Cut at 60 cm - Back
You can use chalk to draw a line, to guide your cutting
Take one half and fold it in half
Cut along the fold - Front x 2
Step 3: Making the Sleeves
Take remeining piece from the full scarf and fold it so that the hemmed edges are together
Cut along the folded edge
Step 4: Neck Opening
Fold the back in half and mark 11cm from the centre fold on both sides
Step 5: Neck Opening
Take the two front pieces and put them on top of each other
Measure 11 cm from the hemmed edge and mark with a pin
Measure 30 cm down on of the long sides (along the hemmed edge) and mark with a pin
Using chalk draw a line between the two pins
Cut the fabric along the line
Step 6: Hemming the Front
Take the two front pieces and hem the diagonal line
To hem fold the edge over twice (approx 0.5cm)
Pin it in place and sew
If you have one you can use a hemming foot to do this
Step 7: Sewing the Front Pieces to the Back
Place the two front pieces onto the back piece right sides facing
Pin across the shoulders
Sew 1 cm from the edge
Zig zag finish the edges
Step 8: Hemming the Neck
To hem the back neck fold the edge over twice
Step 9: Sewing the Sleeves on
Using 1 sleeve piece, fold in half length ways, find the middle put a pin on the fold on the unfinished edge
Open the body piece out flat, place the sleeve on top (right sides together) with the centre fold (pin) meeting the shoulder seam.
Pin in place
Sew and zig zag neaten.
Repeat with second sleeve.
Step 10: Sewing It All Together
Fold the front over the back along the shoulder seam, making sure that the sleeves and body are even.
Pin, as shown in the picture
Sew along the pinned edges
Zig zag to neaten
Step 11: Turn Inside Out
Turn the cardigan inside out
